help please with my heating
5 Oct 2004
hi i have a gravity fed system with a glow worm ultimate 50 boiler i dont appear to have either a 3 port valve or a header tank in my loft.the problem is that when i turn my heating on it only stays warm for a couple of minutes then goes luke warm at best.i replaced the pump and did a drain down and refill i have bled the pump and all of the radiators(the upstairs one are generally quite warm)the boiler and pipes to the boiler are hot but when i switch the roomstat control on to start the heating it appears to use whatever water is around the boiler and then goes cold also when i turn on the heating the boiler doesnt fire up can someone please help thanks
Yes I can help. Learn about punctuation. Then you will be able to write in a manner which is intelligible, making yourself much easier to read and understand.
Posted: Oct 06, 2004 - 10:40 AM
So you thought spelling was important
Believe it or not you can read it.
AMAZING.
I cdnuolt blveiee taht I cluod aulaclty uesdnatnrd waht I was rdgnieg The
phaonmneal pweor of the hmuan mnid Aoccdrnig to a rscheearch at Cmabrigde
Uinervtisy, it deosn't mttaer inwaht oredr the ltteers in a wrod are, the
olny iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit
pclae. The rset can be a taotl mses and you can sitll raed it wouthit a
porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by
istlef, but the wrod as a wlohe. Amzanig huh? yaeh and I awlyas thought
slpeling was ipmorantt!
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Don't be so hard ChrisR, its obvious Theo is short for Theodopolopodis. We want your next post in Greek. Oh never mind, think we have already had it...... :D
