hi I have a ade accenta + remote keypad with a G3 box in the loft it all started with powering down fuse board to fit new outside light & the alarm went off & had to enter factory reset code to turn off. Anyway came in from work tonight & had a bright idea to try & put my usual code in which I did & the panel double beeped I also wanted to set pir to exit mode which I had fitted a few years ago but was just omitting the pir as I hadn't set it up correctly, on doing so I must of entered another new entry code as I heard the double beep but didn't know what number I had put in whoops. At this time it had gone dark I turned the main power & alarm is still going off rang a sparky friend who told me to disconnect the battery on the G3 & pull internal fuses & advised me I would have to put a link in the G3 to do reset any help would be much appreciated.
