help pls ideal classic ff260
  • Thread starter Thread starter mnp
  • Start date Start date
mnp
6 Nov 2009
Berkshire
i am haveing alot of problems trying to sort out a fault with this boiler, fan runs, air pressure swich makes ignition comes on small piot lits for about 3 secounds, then i hear a clicking noise, piolt goes out , it then relit polit again main burnes dont come on, i have chaged gas valve and pcb, still the same what could it be and ideas pls help
I note that you have changed the gas valve and the pcb, both being expensive parts!
Are you gas registered to change the gas valve?
Why did you change BOTH these parts?
igntion stops and piolt goes out staight away, i am thinking it could be pcb faulty ?
Even if he has changed them himself ( whilst unregistered for gas work and endangering his family and neighbours ) then the retail price of the parts is probably about £200.
As its not the gas valve or the PCB a competent RGI will probably find its a simple problem and fix it for £50-£90 !
Many faults are simple and cheaper to have them fixed by a professional than blindly changing expensive parts.
Not by anychance had electrical work done and reversed polarity
shhh
that was one of my thoughts
other involves a lump of china :wink:
That is why we always test the dynamic pressure at the inlet,the polarity etc before we start throwing parts at it!!!!
