HELP! Potterton PrimaF will not light
7 Mar 2005
Hi Folks... been ages since I was in these parts - I guess that's a good thing right? :wink:
I've come home this evening to a buzzing sound coming from the boiler - thought to myself "hmmm that does not sound right or good" and sure enough ... the boiler will not light for either CH or water heating.
I can hear the sprung valves (forget what they are called) opening and closing in response to thermostats so I think all that side of things is good.
What happens is if I turn everything off then turn the hot water heating on, a low buzz - almost like an electrical buzz starts followed by a click which all sounds usual but then when the flames would normally light, nothing happens and the low buzz just continues.
Any ideas? PCB/seized fan?
Any thought most welcome...
:?: :D
I've got an idea, but it's inside the casing and that's RGI territory, sorry!
Thanks twgas - already had a nosey around the outsides, reset switch, sprung valve things (what are they called!)
They are all responding as they should and I can hear the clockwork sound so I've resigned myself to getting somebody out tomorrow.
ANy recommendations in KT4? I used someone of here before who was localish - Chris I think was his name but I can;t find any contact details alas.
Anyway - thanks again ... it's the thought that counts :)
All sorted - was the fan in the end... My thanks to ChrisR as this is now fixed.
