Hi all, I was wondering if anyone could point me in the right direction here. I've got a Boilermate 2000 and it's making a horrible buzzing sound nearly all the time. The only time the buzzing sound stops is if I turn the thermostat up and fire up the boiler it will stop then (only if the timer switch is set to the 1 position, the actual timer seems to be borked). As soon as I turn the thermostat down and hear the little click sound the buzzing comes back.
I'm also getting intermittent hot water but only out of the bath tap! Last night the batch tap was cold while the sink tap next to the bath was scolding hot, also the bathroom radiator is on constantly even if I set the switch on the timer down to the 0 position.
The manual with the boiler is next to useless as it tells me absolutely nothing.
