I now regret it bitterly, but for my sins I purchased a Ravenheat CSI85AT Condensing Combi boiler. The boiler itself is coming up to 2 years old and had been OK until the last few months.
Pressure now drops from the optimum level to 0 in about 24 hours, more if the heating is only on low. I have had several plumbers round, including one who was Ravenheat trained and none of them have conclusively found out what the problem is, so I'd like to ask a wider audience.
What has been tried so far is the following:-
Checked both the overflow pipes outside to make sure that the water is not being discharged through these. There is some water coming out of the plastic pipe, but nothing from the copper one.
I have checked all the rads and all the pipes which are accessible and found no leaks there. This has been done in sections, and under pressure, with no signs of leaks anywhere. The amount of water I am putting in, I would have seen something by now!
System was tested under pressure without having the heating on and the pressure did not drop at all.
Ravenheat's own engineers only cover warranty work, so I can't ask them to come out and throw whatever they need at the boiler to get the thing working again.
I would like to find out if we can use a leak sealer, but want to make sure that the one I go for is approved for use with Ravenheat.
To be fair to some of the guys who have looked at this, the said they didn't want to keep on replacing bits until it fixed the problem as this might cost several hundred pounds for all the various parts/visits etc. I now need to get this fixed asap, and get a certificate of test as we have sold this house and I won't sell it with a knackered boiler.
I'd be grateful for any assistance anyone could provide on here.
Thanks!
Thanks!
