Evening guys,
I'm back again!! So I finally got myself some time today to put up the bell box outside the house. The instructions said I could put the bell on holdoff mode while I'm fitting it as with the cover off the tamper will go off. Instructions said to press the "Omit" key when in Bell Test mode which I did by going into the engineers settings. This didn't actually work for me for some reason so I just put some tape on the tamper switch while I fitted it. Ok so I just went out and came home and decided to trigger the alam to see the strobe. Nothing happened. Keypad is beeping away but nothing on the bell box. No sound no strobe.
I've gone back into the engineers settings and gone to test bell. It says "Bell is disabled" but if I click yes it'll happily do the test. Any idea how to enable it?
I've tried looking online and going through the manual but can't find anything. I recall reading a bit that said it resets itself once the tamper switch is reset.
Thank you
Sam.
Thank you
Sam.
