Was in the loft and noticed a long crack pretty much all the way along the under purlin to the front elevation of the property. It's a deep crack, about 2cm deep and about 8mm wide... see the attached photos how the roof structures down pressure weight has I beleive resulted in the purlin cracking in half and deflecting. I've lined up a straight peice of metal in the photos and you can see how the roof structure has bent and cracked the purlin all the way along its length.
I'm getting a new roof installed in 4 weeks as the tiles and membrane are shot so should I take the opportunity to get some repairs done to this??...is it dangerous as it is or needing urgent engineering attention.
Advice much appreciated!! (Note last photo is upside down!)
