Help!! Trouble fitting strip light in garage
4 Jan 2009
Yorkshire
I need to replace a strip light in the garage, it is a 70w bulb, but everytime i but a new strip tube in it blows and trips the electrics. Has anyone any idea what i am doing wrong? I am using the correct voltage tube, im onto my 3rd and its costing me a fortune!! :confused:
Any help will be greatly appreciated!!
Cheers
Chris
Hi jj4091,
Thanks for the quick reply! Do you really need a new fitting?! It seemed to be working ok before just the bulb was flickering slightly and would take a while to come on, then it just gave up the ghost! So thought it would be just a new bulb!
Oh well its a rented house so will just charge the landlord! :)
Thanks for your help!
Chris
No didnt try changing that, is that situated on the main unit?
Yes it should be on one side or the other it is a round part that when turned comes away from the main light and is a small barrel shape with 2 metal pins on it. It will prob be 5-80w FSU type.
the choke / ballast has gone short cicuit, throw the fitting away and get a new one
