I've have recently had a new bathroom fitted, and now I have really low pressure in my sink and bath.
I used to have quite high water pressure (at least high enough that I could use the hose on the bathroom taps - which is not possible now as the pressure is so low that the button to switch the flow of the water from the taps to the hose keeps popping up !!!), but now it seems to be pathetic
They moved the cold water pipe from being in an external wall, to being in an internal wall, but otherwise all the units are pretty much in the same positions as the old bathroom. I also noticed they installed some lever shut-off valves in the loft
Any help/advice that you can give is muchly appreciated
Cheers
Mark[/b]
___________________________________
lynda, moderator
please note forum rule 5 you can use the
button to correct it
Cheers
Mark[/b]
lynda, moderator
