Hello, I have a monobloc tap on our kitchen sink (see pictured) The tap works but recently water has began springing from the area marked with a red arrow, about 20% of the water flow of an open tap.
Im sure this is an easy fix, this is a fairly standard tap set, probably a washer I would just like to hear opinions of what the most appropriate part is to buy? (I dont want to unscrew it and be left without a tap at all.) I hav no technical drawings of the assembly and have had a look online without any luck.
The neck seems to have 2 flattened faces on opposite sides, probably for unscrewing, I can unscrew this if necessary.
Note apologies for the limescale we live in a hard water area!
Here are the photos
Here are the photos
