Help with build over agreement
28 Dec 2017
Hi was wondering if its a easy thing to draw up my self or would it be better to pay someone. Im doing a six metre extension but have a manhole in the garden and i believe my neighbours waste also comes into it. Thanks
Yes Thames water. But can't do a self assessment because of the manhole i believe. That's what i understood from reading the self assessment agreement
Building over a sewer or lateral drain
Self-certified agreement criteria
1. I confirm the diameter of the public sewer/lateral drain is 150mm/6inches or less
2. I’ve verified the location and depth of the public sewer/lateral drain I intend to build over
3. I understand the liability for any damage/operational issues to the public sewer/lateral
drain caused by my building works, rests with me
4. I’m not aware of any easements or restrictive covenants which would prohibit building
work over or close to the public sewer/lateral drain
5. I confirm the public sewer/lateral drain is not made from pitch fibre (instead it’s made
from clay, plastic or concrete)
6. I confirm the public sewer/lateral drain is gravity-based foul, surface water or combined
(and is not a pressurised/rising main)
7. I confirm the depth of the pipe from the existing ground level to the bottom of the pipe
(invert) is less than 2000mm
8. I confirm the that the pipe is at least 500mm from the external face of my building
9. I confirm there are no internal manholes or inspection chambers within the footprint of
my proposed building
10. I confirm that no manhole will be added, removed or relocated
11. I confirm that my proposed structure will not require building over more than 6 metres of
12. I confirm the extension will utilise strip/trench fill foundations that will be a depth greater,
or equal to the invert of the sewer (piled or raft foundations require a full build over
agreement).
13. I confirm there will be at least 150mm horizonal clearance from the public sewer/lateral
drain to the floor slab or the edge of the foundations, and will be protected in line with
H4 (Building Regulations 2010) and Thames Water specifications
If you are having plans drawn by someone, then they should be detailing how the drains are going to be bridged, or diverted - drawing details not a text note, and you would use this as part of your application.
If you are not, then you can do a basic stick drawing to illustrate how you will safely protect the drain or move it.
Just want to do whatever is minimum for it to get approved to be honest. Cheapest person i found to do is 250£ including the 70£ application fee
