I have a 2-Way Switch wired as in the Link shown below,
Old 2-Way Switch
I have purchased a 2-Way Dimmer Switch as shown in the Link Below,
New Dimmer Switch
As far as I can see there is no common on the Dimmer Switch, I assume that the A1/B1 From the OLD Switch will goto the 2 L1's of the Dimmer Switch, but where do I connect the ACOM/BCOM Link & the Red, Switch Wire also in ACOM??
Is it in the ~ Terminal or the L2 Terminals, If indeed I can use the Dimmer that I have purchased??
Any help would be appreciated. I understand also that I will need to put an earth wire from the back-box onto the Brass Plate, and that all the Black Common's will stay as they are, into a connector block.
Tsg9
Old 2-Way Switch
New Dimmer Switch
Tsg9
