Hi
Got called by a customer as their bath gurgles every time they flush the loo. I went to the loft, removed the durgo valve, flushed the loo and hey presto, no gurgling so I thought the valve must have jammed.
Fitted them a new one and the gurgling is back!! Thought it must be a blockage somewhere so I’ve cleaned all the traps as well as I can (everything is tiled in) - no joy!!!
Any other ideas? Like I said, EVEYTHING is tiled in, I’d like to put an new air admittance valve on the 2 inch pipe I’ve found that I can get to (after cutting an access panel in the adjacent bedroom) but there is very very little room, and there is very little movement on the pipes!!!
Is there such a thing as a strap on boss to 50mm??
See pictures of the only pipe I can find, this is fed by the bath, shower and the basin! Customer has only recently started having problems though.
Mike.
Mike.
