Hello all...
Turning to forums for help as I'm reaching the end of my tether...
I have an integrated Nardi dishwasher (never heard of them, similar design to Baumatic etc, so assume its just another generic make), and on the weekend, someone who shall remain anonymous, decided to put some fairy liquid in the dishwasher - anyway, I heard the error noise (beep beep beep several hundred times) and got up to find the dishwasher slowly filling up with bubbles... Now it didnt overflow, I just switched it off, left them to dissolve, and put it on a normal full wash cycle... foolishly assuming it was working as normal...
Anyway when I went to the dishwasher the next day, and saw the tablet had just sat in the bottom of the unit, not getting more than mildly soggy, I realised something was up. Starting another wash cycle, it started making some very chuggy noise, followed by silence... and then that disconcerting smell of a motor or pump trying to do something and obviously not being able to... so I switched off, and left it another day...
Did a bit of searching online, read something about sticking vinegar in there, so tried that, no luck... read another about doing lots of rinse cycles, did that, still wont work properly...
So, I left it another day, and tried again this evening, still the same, turn it on and it sounds like its going to work normally, lots of noise and then long long periods of silence, and worrying smells (at which point I turn it off again).
I've tried running it with the door open, to see what exactly is happening, and on rinse, it drains the water out, then spits a bit of water up into the chamber, but all there is, is a trickle of water coming down the sides... on a full cycle, it whirrs for a few seconds then nothing happens at all...
So, any idea what to try next?? My last resort will be obviously to rip the damn thing out and check all pipes etc, but, as I mentioned it is integrated, so this may end up being a timely job... plus I don't really have a clue what im doing (how hard can it be)
Would also like to just point out that there are no bubbles visible in the machine, they all went within the first night!
Welcome all replies, thanks.
