- Joined
- 16 Mar 2021
- Messages
- 4
- Reaction score
- 0
- Country
Hi there - newbie here looking for some help.
I am not gas safe registered, and not looking to do this on a DIY basis, but I need to know what to tell an engineer when they visit. The boiler is on a Corgi service plan/warranty (which I will discontinue soon).
Last summer the property had a refurb. It's a small property, and prior to the refurb it had a standard HW tank with a header, and a CW tank in the loft. When converting to mains, I had the option of either replacing the (fairly new) HW boiler with a combi, or replacing the HW tank with a Megaflo. I did the latter, opting for a 125l.
This was fitted, and the boiler tested. The fitter noted a PCB fault on the boiler as it wasn't responding to a call for heat, but test mode worked ok. There were no rads installed yet.
Called Corgi out, who took a look and immediately said it was because there were no rads, boiler is fine. They would come again when the rads were on if there was still a problem.
Refurb carried on, and unfortunately the wall stat went into the skip, but the rads went on. Still no response on a call to heat (test mode worked ok, and rads heated when valve turned on manually).
Called Corgi out, who took a look and immediately said it was because there was no wall stat. They said they'd come back if we replaced the controller and there was still a problem.
Had the controller replaced with Honeywell Evohome (it's going to be beneficial to control this remotely). Boiler still didn't respond to a call for heat.
Called Corgi out, this time they sent an ex Vaillant engineer, who tested the boiler a bit more thoroughly. He said there was nothing wrong with it, but that it wasn't wired up to the pump properly (this came as part of the Megaflo). He told me that when the boiler is new, there is a jumper between two points on the PCB which is sometimes removed, and if I wanted heat he could put it back, but there would be no overrun. So, he put it back.
Now, the boiler does seem to respond - pump kicks in and the flame goes on. However when the call for heat stops, the pump stops but the boiler does not. This results in an overheat lockout, and I'm not sure it's that safe.
So, in total 5 separate gas safe engineers have been involved, I've had no proper hot water or heating since last summer, and I just want to get it sorted out. I've done a search here for an engineer, but there are none in the area (CO14). Any clues would be very welcome. I will make sure whoever looks at this is ok for unvented. The original fitter is nowhere to be found.
Thanks!
John.
Thanks!
John.
