Help with slow leaking close coupled toilet
Hi again.
Managed to unscrew the flush valve and the other part that actually fits into the waste.
This part just unscrewed - there is no bolt under the cistern holding it in place. There is a rubber washer under the valve, and I'm pretty sure this is where the leak is.
I cleaned away all the gunk (plumbers mait?), and reassembled, but, when screwing back up, the lugs don't align up so I have to leave it about 1/4 turn lose.
Should I reapply the gunk, as I don't see how I'm ever going tighten enough to stop the leak?
From the top down, you should have:
The flush valve
The flush valve base
A rubber washer
The bottom of the cistern
And a large nut that holds the flush valve base in place.
If you haven't taken the cistern off, the nut will now be sitting in the space below the cistern.
You can't put it back together without taking the cistern off.
Mind you, if it's gunked up in plumbers' mait it's probably been bodged before. Maybe it is time for a new flush valve, they're not terribly expensive.
The flush valve
A rubber washer
Definately no nut underneath. I can get my hand down the drain hole and there's nothing underneath. The flush valve base seems to thread up tight, just doesn't align up?
