- Joined
- 11 Jan 2004
- Messages
- 47,099
- Reaction score
- 4,095
- Country
I have this evening done all the above tests and the results are all as expected.
I definitely get 240v (using a two pole tester) on this circuit when the switch is closed and 0v when it isn't.
However if I touch the screwheads on the choc block once the light is wired in I just get the continuity buzzer and LED.
In each case have you been testing between the switched live (the terminal with red and black connected to it) and neutral?
What happens to both lamps (the CFL and the GLS) when you connect it to permanent live loop and neutral?
