Dear all
I have to replace the washbasin waste in my bathroom.
The total length of run is just over 3.5m. The existing 32mm waste runs from the bottle trap to the outside then drops down and joins vertically into the horizontal 40mm bath waste outside the building via a swept tee. Water is very slow to flow away at the moment so I want to improve flow.
Due to the total length of pipe run can I get away with 40mm diameter pipe?
Will I need an anti-syphon bottle trap?
As basin traps are normally 32mm dia can I get a basin trap with 40mm outlet?
Many thanks in advance.
