Heringbone drive, cleared, powerwashed, Now What????
17 Jan 2007
Yorkshire
Ive recently moved into a new house and the drive was laid with heringbone(sp) bricks. The drive hadnt really been looked after, there were weeds growing throughout, I pulled all the weeds out and spent 5 hours yesterday powerwashing the whole drive, removing all the muddy deposits between the bricks where the weeds had been growing, question is.
Do i now need to point/ brush sand and cement into the whole lot?
Should i treat with weedkiller for a period prior to doing this?
Any advice would be appreciated
Andy
You need to buy some kiln dried sand an brush it back and forth to fill the joints and stop the whole lot moving around. (long term i mean. Its not going to do it overnight or anything)
If its small, like under 50m sq, treat it now and after with pathclear or similar. If its bigger then sand it first. There are sealing products but i personally wouldn't recommend any of them, others may have found one that works.
Easiest way to keep it depending on size will be to buy some industrial bleach and scrubb it on every few months. This will keep it clean and moss/ algae free as well as killing weeds.
Be caeful with the runoff though as your lawn won't appreciate it.
its very fine when dry and can be swept into the gaps very easily, and fills them fully, as opposed to more coarse sand that leaves voids and weakens the paving bond
youre welcome, did you see my reply about the walling to the pond you asked about in tools and materials breezer?
IMHO the new formula Pathclear is NBG (I think there are quite a few posts on other websites saying the same thing too). Very expensive, doesn't kill lots of types of weeds, definitely doesn't suppress new ones growing up. Nothing like it used to be!
