hi iv got ldv pilot you start in in the morning it runs like its on 3 cylinders and knocking up top and lots of white/ blue smoke but if you drive 1/4 mile smoke stops it just runs better, can anybody tell me whats wrone with it please.
Heater plugs, or coolant temp sensor, or partial air lock in the fuel line, or injector pump timing. Best to get it plugged in and read the fault codes. Hopefully it will show up something, otherwise you are just guessing.
hi guys thanks for that iv put in new glow plugs its just i left van for 2 days then started it and it was like that, iv checked fuel pipes changed 1 pipe but can't see air in the clear pipes.
I'd still check each glow plug individually first - you are looking to see around 1 ohm on each plug.
Next, check the time duration of voltage to the plugs.....on a cold morning it should be around 8 sec.
John
To test the plugs, you need to have a meter capable of reading very low resistances, I'm afraid....the ohm being the unit of resistance.
Your voltmeter is fine for reading the voltage reaching the plugs, but no use after that. Any cheapo multimeter will do!
Do you think its the same cylinder thats grumpy every time, or are you not certain?
John
hi john i think its the same cylinder every time, iv tryed cracking the injectors off but it just dies till i do them up again if you no what i mean, but i do that 1 at a time
Or a flying lead with a fuse fitted from the positive terminal on the battery, to each plug. You should see current flow (a spark) when you connect/disconnect.
Don't leave it connected for to long, (a second at the most or you may blow the plugs) and don't touch the engine or you will blow the fuse. The wire MUST have a fuse fitted for safety.
