LDV Pilot 200 1.9 Fuel cut off solenoid
2 Nov 2010
Humberside
Hi group,
Help with my LDV van please.
I have no voltage at the fuel cut off solenoid so engine won't start or run.
I've removed the plunger from the solenoid so can run the engine
but where should I be looking for a fault in the wiring?
I've check for continuity between the solenoid connection
and the connection block behind the fuel filter (white wire?)
and that seems ok.
So wiring fault would appear to be inside the cabin but difficult to trace
where it's going.
What should I be looking at?
probably the ignition switch if its an old ldv, difficult to say without a wiring diagram. i will see if autodata has one and get back to you.
You should be able to find a live ignition feed somewhere to connect it to.
Peter
