We've fitted a cloakroom to our kitchen and where the basin can go there is a sold and or a stud (about 70mm thick excluding plasterboard).
We're gonna hang a wall hung basin on the stud and get one of those chrome plated bottle traps for the waste.
The basin will have a monobloc basin mixer.
My problem is that the plumber isn't in for a couple of weeks and in the meantime I need to run the hot/cold feeds and waste inside the stud so it can be plasterboarded and skimmed before the plumber gets in. He can then take the waste and feeds in the floor void to where they need to go.
So not being a plumber can I get some advice please:
1. For the feeds - to reduce any joins and to minimize leaks am I best to get a long (1 - 1.5m) flexible tap connector and run this from the basin, through the stud to the floor void beneath?
2. Run a length of plastic pipe and use a small tap connector hose for monobloc basins? Is there enough give in a plastic pipe to bend to do this or am I best to use an elbow and two straight runs of pipe?
3. Or is there a better way - we basically don't want the wall hung look to be undone by unsightly hot and cold pipe work.
For the waste:
1. In a 70mm stud is there enough room to use a 90 degree compression fitting that will connect to the sleeve of the bottle trap?
Any help will be greatly appreciated.
Cheers
John
For the waste:
Cheers
John
