high pitched squeal when heating is on
26 Jan 2005
on tuesday 25/1/05 my boiler (vaillant combi boiler just over a year old)
started to make a high pitched squeal / noise only when the heating is on, so i bled all radiators no air in any of them. Only way to stop this noise is to turn the heating off and then run a tap for about a minute any ideas please :?
Perhaps you have a pig stuck inside the casing, it'll be the same pig you see flying when you get someone who knows what their on with to fix it.
This happened with our boiler at work. Squeeling pig stopped when hot water tap open. Turned out to be a fault in the boiler that needed fixing.
But perhaps yours is different....
