How exactly did you remove the scale and sludge from the h/e? For example, a garden hose is woefully inadequate?marcoslupo said:Have checked again and the 'domestic' side of the HE is a black colour, but not full of scale. Water seems to run through it OK when I've fired a garden hose through it!
The same question applies to the rest of the system - there's little point in replacing the h/e until the rest of the system is clean.
Classic symptom of worn or blocked pump.marcoslupo said:With all of your advice, I think I'm gona have to flush it AGAIN and check what comes out. Might try to get some mains pressure through the rads at the bottom of the house as they seem to not get quite as hot as rads on floors 1 & 2.
Not without cleaning it and the rest of the system first.marcoslupo said:Do you guys/girls agree that if it doesn't get any better or cure the problem.......I may have to splash out and try a new pump?
