    Dismiss Notice
Hikvision Ip Cameras
Discussion in 'Alarms, CCTV & Telephones' started by steveo44, 17 May 2016.
  1. steveo44
    steveo44
    29 May 2010
    268
    Thanks Received:
    21
    Nottinghamshire
    Country:
    Where is the best place to purchase Hikvision Ip cameras from?
    I'm in the Uk not that that really matters i guess these days.
    Thank you.
  2. Sponsored Links
  3. secureiam
    secureiam
    20 Jun 2014
    4,653
    Thanks Received:
    578
    Lancashire
    Country:
    From one of the 4 main distributors in the UK due to HIK Visions policy of support and pricing
  4. steveo44
    steveo44
    29 May 2010
    268
    Thanks Received:
    21
    Nottinghamshire
    Country:
  5. secureiam
    secureiam
    20 Jun 2014
    4,653
    Thanks Received:
    578
    Lancashire
    Country:
    HIK VISION have there distributors listed on their website by country, in the UK I believe the four main distributors are strictly trade only.
  6. steveo44
    steveo44
    29 May 2010
    268
    Thanks Received:
    21
    Nottinghamshire
    Country:
    Not much good on a Diy forum then!
  7. sparkymarka
    sparkymarka
    16 Feb 2011
    8,070
    Thanks Received:
    1,225
    Sheffield
    Country:
    Try map security , they stock Hikvision a couple of members on here recommend the supplier !
    • Like Like x 1
  8. Paulj48
    Paulj48
    7 Jun 2014
    347
    Thanks Received:
    37
    Manchester
    Country:
    I got mine as grey imports cheap from ebay but the likes of amazon sell a large range of genuine stock with good customer service if needed.
  9. secureiam
    secureiam
    20 Jun 2014
    4,653
    Thanks Received:
    578
    Lancashire
    Country:
    MAP security is probably your best option outside the main 4 as others have rated this supplier.
  10. Sponsored Links
  11. madwayne
    madwayne
    21 Nov 2005
    54
    Thanks Received:
    Country:
    how much should I expect to pay for a pro to fit 5 x 4MPcameras and an NVR?
  12. dibbles00
    dibbles00
    21 Dec 2016
    21
    Thanks Received:
    Country:
    I too got all of my Hikvision cameras from ebay (shipped from China). They all work flawlessly and connect to the mobile app with ease. One thing sellers have all stated on their listing is to not update firmware, which is something to bear in mind. However, for the cost saving I've had no issues with them; all work sound, connect to iSpy and X-Protect on server, connect via browser and also mobile apps.
    Saying all of that, I purchased them nearly two years ago when exchange rates were really good. It's best to shop around and speak to owners to see what their experiences are.
  13. dibbles00
    dibbles00
    21 Dec 2016
    21
    Thanks Received:
    Country:
    If you want 5 decent Hikvision IP cams, CAT5/6 cable reel and a decent POE Network NVR you'll not have much change from £950. Fitting IP cams is dead easy and I fitted mine myself with no prior experience. I used a POE switch instead of a dedicated NVR for cost (doing house up at the time). The beauty of IP cams is that you can run a single cable to where ever you want the cam and buy it later to connect up. Again this is what I did for cost. Slowly over the last couple of years I have been buying cams and now I have 4 in total with another one on the cards soon.
    Connect NVR to your router. Run 'x number of' cables from your NVR to each cam and connect them up. It really is that simple with modern IP cams.
    I read loads of forums and worked out the XProtect free was pretty good software to use for free. Because you want 5 cams you will need a more expensive NVR too so bare that in mind also.
    I'll have a stab at saying someone would want a few hundred to install and setup?
  14. topman870
    topman870
    18 Dec 2004
    55
    Thanks Received:
    Country:
    Hi Dibbles00,
    If i have a dedicated POE NVR, is there a way for me to later on patch a camera anywhere on my LAN or does it have to go directly to my NVR?
    Thanks!
  15. monsterink
    monsterink
    2 Jan 2014
    85
    Thanks Received:
    2
    Essex
    Country:
    Directly
    My bad, I thought logically to use Poe.. you would have to go directly to the Nvr.
  16. sparkymarka
    sparkymarka
    16 Feb 2011
    8,070
    Thanks Received:
    1,225
    Sheffield
    Country:
    It can go on the network anywhere if powered locally or if you use a POE injector
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
