- Joined
- 24 Dec 2022
- Messages
- 10
- Reaction score
- 1
- Country
Hello good people I hope you can steer me to what I should do to achieve the above. My system is a Y plan with my boiler, hotwater tank, water supply tank, 3 port valve and wiring centre all located in my attic. I have installed hive and all appears to be working fine by connecting the live and call for heat together at the wall stat end.
Ideally I would like to disconnect at the wiring centre but this where I get confused as its a Honeywell sundial type. The live wire I beleive is the one located in the room stat block along with the earth. I cannot see where the yellow call for heat wire is likely to be connected, or even where it is !!
When I installed the hive 2 channel reciever the wiring was the same as my old programmer but there were some additional wires that were either connected together or tucked away behind the programmer. In my photos you will see i numbered the wires as I disconnected them from the old programmer. I dont know if its of any significance but the red wire from the labelled No1 cable connects together with the yellow wire (red sleeve) on the the No 4 cable. Is this my thermostat yellow wire
What I hope to acheive is hiding the thermostat dead wires in the wall cavity (but accessible just in case it needs to be reinstated) and bridging whats needed at the wiring centre.
A bit long winded I know but any advice /direction would be greatly appreciated.
