In my extension I have a solid brick wall which has plasterboard attached to it. I was feeding my TV coax cable down the back of the plasterboard and it was getting stuck somewhere. As a result I picked up the lump hammer and put it through the plasterboard. As luck would have it I found the cable first time!
As a result though I now have a hole in my plasterboard wall which is approx 20cm x 20cm.
How should I fill this? Whatever goes in needs to be a little flexible because the rest of the wall does flex a little bit.
Cheers.
Chris
Cheers.
Chris
