Hole in the wall(!) - how to fill?
1 Dec 2014
There is a hole at the back of one of the cupboards in my kitchen which goes all the way to the outside of the property. It's approximately 3 inches in diameter. I obviously don't want the inside of the cupboard exposed to the outside, and I can also feel it letting a cold draft in, so could people recommend a cost-effective way to permanently fill it?
View media item 87933
Pop some mortar in a carrier bag and poke inside, when set fill outer hole and inner with more mortar mix .
Thanks for the suggestion - is this something I could make myself? What about some expanding foam sealant?
As per foxy, or you could jam a half brick or similar in the hole and cement up to that.....anything to prevent the cement from falling right through.
Forget about the foam here.
John :)
John :)
Thanks, John. The thing is, it's very difficult to access, it was difficult even just taking the photo, hence why I thought expanding sealing foam might be the best way to fill it. Is there a specific reason why I shouldn't use foam?
For sure, foam has its uses but its not particularly weather proof although it is claimed to be closed cell. Its also pecked away by birds over time.
I can't tell from the photo where the hole actually is.....is it possible to fill from the outside? That's really the important bit - to keep the vermin and the weather out.
John :)
With difficult access you could use a section of waste pipe, pop bag of mortar in the end, offer pipe to hole and then push out the bag into hole with a length of stick.
