hole next to drain
27 Dec 2010
Lincolnshire
View media item 29378 View media item 29379
Hi there,
after clearing alot of snow off the drain on Christmas eve, i discovered that a hole has appeared next to the drain. but as it is not connected to the underground drain pipe in anyway any water just absorbs into the ground.
i have put a flat rock and cover over the hole it to try and keep it as dry as possible, and as it is a rented property i have contacted my letting agency, who im waiting to hear back from.
i was just wondering what may have caused this to happen, i was a a bit concerned it might end up getting bigger?
if it is of any help the drain area is at an angle all the way round so is lower than the rest of the path, if you need anymore pictures just let me know
thanks for your help :)
[/img]
Looks like a void has appeared under the concrete, possible through ground shrinkage over the years. The cold has got to the concrete, causing a piece to break away. Fill it in, and concrete over to seal, doesnt look like too much to worry about. If the concrete hadnt broken away you'd be none the wiser!
I'd start to worry if the house develops major cracks, but even then if you're renting its the landlord's problem.....
check for furry friends that might not be small furry friends !
