hole size for 2* 2.5mm twin and earth cable
30 Mar 2015
what size spade bit do I need to pass the above through some timber please?
Thanks in advance.
Drill the biggest hole you can get away with structurally. Be careful when pulling the second wire through if you aren't threading both wires simultaneously; if it rubs on the first with reasonable pressure the friction will easily melt away the PVC outer sheath of the first wire, possibly the inner insulation on the cores
thanks guys. I was away from home and needed to pick up a spade bit. I've gone with 20mm
