Replaced a few downlight fittings as I couldn't open them to replace the bulbs, guess the fitting had fused together or something!?
On removing the old fitting the ceiling was slightly damaged and there is a slight hole around the new fitting (see pic).
I have tried using some pollyfilla but cant get a nice finish and looks a mess. Is their a better way to fix this? I see you can buy a bigger downlight fitting which would cover it up but they seem to be a lot bigger than the standard size and not an extra 3cm or so which I require.
Any other suggestions?
Many Thanks
Rob
Many Thanks
Rob
