I am going to install a bar shower on a wall that it battened and then has Marmox board, and then shower panel.
I will be sealing the joints in the Marmox board, and the fixing screws and also sealing around the pipes where they pass through the marmox.
When I am fitting the shower valves, and also the wall fixing bracket, I need to drill and screw through the shower panel and Marmox board. I'm not going to be able to seal those hole in the same way that I seal the screws that fix the marmox to the battens.
Does that matter? Is there anything that I can do to minimise the fact that the fixings are somewhat compromising the Marmox?
Any thoughts greatly appreciated.
