- Joined
- 27 Jan 2008
- Messages
- 27,837
- Reaction score
- 3,373
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Yes I have used crowbar protection but the point is all fuses and protection is only good if the fuse or protection is itself from a supplier who has said it is suitable for that use. I had an accident which was made worse because wrong colour relays were used. We all knew relays for personnel safety were always yellow or red black relays may be used to protect the machine but not personnel. So since the relay was black in colour it was removed to prevent damage without any alarm bells being rung as to the danger to personnel.A core issue that many PIC programmers fail to consider is fail-safes.
A well written program is only as stable as the silicone it's programmed on. As such, it is imperative to include fuses, MCBs, external watchdog controllers... etc
My favorite fail safe system is a high current relay held open by a watcher circuit. If the watcher circuit detects an error OR fails itself, the relay closes, shorting the supply. That then blows a fast blow fuse and removes power to the circuit in one go.
Fubar.
It is so easy to look at a relay and say that black one is half the price of red one I'll use black.
I have also made mistakes because I did not foresee what could happen. I had a safety switch remove the supply to an air solenoid when a door was opened so the ram would stop. What I had failed to realise was the ram may stick and I needed to dump air in cylinder as well.
I have found many safety systems which were dangerous in one case hitting emergency stop could cause one ton of concrete to be dumped on the operator. "Po body is nerfect". So the idea is always to get at least two people involved so something missed by one likely will be seen by another.
Even the big firms get it wrong. My father-in-laws automated garage door which needed to be operated to gain assess to consumer unit had no manual over ride! Ups.
Writing the manual is also a problem. Read the instructions for starting a Model T ford and they forgot to tell you to take it back out of gear and if followed by letter it would run over you.
The problem is the more we protect the more likely to go wrong because people don't watch out for their own safety they assume it will be fail safe. So when coming to a personnel gate on a level crossing they will assume you will not be able to open it if a train is coming. However that's not the case years ago we would have been far more careful.
