Honeywell 2 Port Valve Heads
4 Jan 2009
Herefordshire
Are the heads interchangable between the 22mm and 28mm valves ?
I just got worried as the 28mm has the extra white? wire for the NO contact. and started to worry whether they will fit (assuming the white wire is not connected)
Yes, you must put the white wire in an insulated terminal block.
Not leave it sticking out uninsulated in a pile of damp towels like a BG fitter did on a job I saw last year!
if you have a c plan then you will need the white wire.
