Since installation, I have had numerous problems with the thermostat on our CH system.
it usually clicks the boiler in, but after a couple of mins it clicks it off again (even though the transmitter is showing boiler on, the relay box is turning itself off)
each time it starts to do this, I have been "advised" to re-bind, after which it usually works for a couple of weeks, this time I have tried to re-bind, twice and replaced the batteries (with procell, not cheapies)
Ive not found the spec on the range of this unit.
in a straight line from the unit to the receiver are 2 solid brick walls, and with it being mounted on the end of a wall, about another 4 feet of solid brick, and a wooden staircase.
now, I do some work in theatre, and radiomics are a similar frequency to these (868-868.6MHz from the info I have found) and I would expect little if no transmission thorough that amount of blockwork from a 30mW transmitter, so in my mind, the large proportion of the problems lie here, can anyone confim this before I start to get cross with the installers.
