I have an infuriating problem with a Honeywell CM67 wired programmable roomstat (which is in the hallway, where there is a radiator at the opposite end without TRV’s - connected to a Baxi 105 HE Instant combi boiler in the kitchen).
Allowing for the optimised start, when a timed preset temperature rise (in my case from 16 deg to 21 deg at 5 p.m.) is arrived at, .the boiler fires and cycles as expected until the preset temperature of 21 deg is reached (If anything, this is too hot, but read on!) However, after that the displayed temperature remains at 21 degrees, even though the ambient temperature everywhere in the house falls noticeably. If left unattended the boiler will eventually cycle again upwards of AN HOUR later!! Then the same thing happens.
If (as we often do!!) we get too cold in the meantime, and try temporarily increasing the required temperature (using the “up arrow” button) to 21.5 degrees, nothing happens – the boiler isn’t switched, but after a few seconds the displayed temperature climbs ‘magically’ to 21.5 degrees!! It’s only if I increase the required temperature to 22 or 22.5 degrees that it switches the boiler on again. We then end up too hot, then become too cold as it takes ages for the boiler to cycle again.
I have put up with this since I fitted the stat some 12 or so months ago – yes I should have done something about it before! It may simply be “faulty”, but I have to say that I had previously bought an “Invensys” programmable stat which I’d returned because I had similar problems – long boiler cycling times once preset temp reached - plus it seemed over-complicated!
This all makes me think it’s the boiler somehow, but I’ve tried a standard mechanical stat and the boiler cycles as expected – once every 8mins or so, and the stat is simply switching the 240 volt supply to it.
I’ve tried resetting the CM67 back to the factory defaults – also tried increasing cycle times to 12 and changing the proportional bandwidth and disabling optimisation - to no avail and have ended up using the selectable temperature change buttons to set a low temperature of 19.5 degrees in the early evening then progressively increase at 45 min intervals to 22.5 degrees, but the long cycling problem (and us getting too hot/too cold) still remains at all preset temperatures. Can anyone offer advice or had similar problems?
