Hopefully someone can help with this issue I had yesterday....
It started when my home router lost power, sometime later my studio (a separately alarmed building) started alarming. My wife went to reset it and told me it said something about Com 4.
When I got home from work I had a look at the situation, it appears that when my router in the house lost power, sometime later the studio went into a alarm state with external sounder triggering. As I only have the Ethernet board to allow me to connect and reset the alarm should it trigger while on holiday I do now want it to trigger a full (or any) alarm should it lose connection to my router or the internet!!!
So that's the first issue, I want to disable the com 4 error triggering the alarm.
Then the fun started.
Obviously you can see from the log below I was into several menus trying to find the things I wanted.
Since I updated the phone I have not logged in using the app so had to set it up again, the problem I had was the user number, I originally tried user 1 then 01 then 0 then 100, but none would connect, after several attempts it locked me out for a time period.
Shortly after I had a visit from a neighbour, saying my alarm was making a noise. On investigation it was chirping for about 3 seconds every say 2 minutes roughly. The keypad would cycle through the 'normal' home screen I have then ****************** on the top row and nothing on the bottom row, then blank, then back to the home screen. sometime during this sequence the the outside sounder would sound as above. I could not enter anything on the keypad.
I tried dumping the mains, then the mains and the battery to reset the system, after a few goes I appeared to have control again. As you can see I also put the zones I use into Soak as it was starting to get later in the evening (the only time the clock was 100% correct on the log below is 21:05 other times are not accurate)
So as well as my disabling Com 4 error question above I would really like to know what sent my alarm crazy, was it me trying to set up remotely on my phone app? was it com 4 playing up again? Maybe the log will tell an alarm guru what was going on, if so please let me know.
One final thing, I thought I have used an option before when I installed to disable the external sounder.... But can find the menu number now?
Steve.
Flex 20 Log
Steve.
Flex 20 Log
