Installation is of a galaxy 2-12 panel with 2 x keypads, 4 x bosch blue line gen 2 grade 2 pirs, 2 x door contacts and 2 x pyronix deltabell sirens.
I have managed to power up panel with no faults by adding 1k resistors I made sure there was no faults I then 4 x pir sensors all working fine. However I am struggling with a few issues as I have not used the galaxy panel before and wiring was already done, I am just carrying out commission and test for a family relation.
1. The siren is not working correctly so far have only wired in 1, I have enabled battery, set to scb and is set to default negative applied, connections as below;
Bell Box Control Panel
+ 12v Bell +12V
-12V 0V
Strobe Strobe
Bell Bell +12v ?
T Trigger
T T
Then added a link from T on control panel to 0V
The siren has flashing alternate led’s but fails to operate when alarm is set off do I need to program galaxy 2 for output ? also please confirm wiring I am unsure of bell to bell +12v connection. Also when connection of 2 sirens how do I loop the tamper. I am confident with a multimeter and can measure voltages and continuity.
I have attached scan of installation guide and panel layout.
2. How do I add and wire up the door contact as panel requires 2K can I use 2 terminal and 4 terminal or should I scrap those purchased and buy these ?
https://www.securitywarehouse.co.uk...n-contact-grade-2-green-resistors-p-4175.html
Your help and suggestions appreciated in advance, I have not wired up the galaxy panel before I have wired up many Honeywell panels in the past including the accenta / optima range.
+ 12v Bell +12V
-12V 0V
Strobe Strobe
Bell Bell +12v ?
T Trigger
T T
