Wondering if anyone can help with this issue thanks in advance for any advice you can provide!
I'm currently in the process of attempting to replace an old basic screwfix alarm panel and keypad with a Honeywell Galaxy Flex 20 panel and Mk7 Keypad. I've tested the panel and keypad before installation which exposed an issue with the keypad's LCD display which wasn't connected properly inside I resolved this problem and they appeared to work fine and talk to each other no problem there.
Now the panel and pad have been fitted using the existing cabling from the previous system i've come up against an issue - when I power the system on I just get either Blocks on the pad and it beeps or flashing ********* with the beeps. I understand the flashing ******** indicates an issue with communication between the panel and pad but cannot see anything wrong wiring wise - even swapping the A and B connections to the spare pair of cables in the 6-core wire which is running through the wall to the pad made no difference.
My thoughts are:
1) there is a fault with either the pad or the panel
2) there is a fault with one of the existing sensors or other part of the old system which is causing some interference with the new panel?
3) the 12v power supply running to the pad is somehow interfering with the data signal running down the same cable?
Any thoughts or suggestions would be appreciated as I have currently completely run out of ideas on this one!
My thoughts are:
