I am looking at installing the above pack which combrises of a ST9120C and a wireless DT92E. If the timer is set to auto and the temperature is adjusted (increased) will this override the timer IF the timer isn't currently meant to be on? I had assumed not until I read the following from the manual:
Can I override the Timer from the DT92E thermostat?
As well as changing the set temperature from the DT92E, it is also possible to override the heating system on or off from the DT92E. This is only possible if the ST9120C is in AUTO or ONCE Modes. If ST9120C is in CONT mode it will not be possible to switch the heating off from the DT92E. Similarly, if ST9120C is in OFF mode, it will not be possible to switch the heating on from the DT92E. If these latter overrides are required it is first necessary to change the ST9120C mode setting to AUTO or ONCE.
Now I am confused
I want the timer to be hidden from guests and they can only control the temperature from the stat during preset times.... the manual would suggests this can be overriden?
Can anyone confirm?
Thanks.
Now I am confused
Can anyone confirm?
Thanks.
