Honeywell Thermostat Replacement
17 Aug 2011
Birmingham
Hi
My combi is controlled by a Honeywell CMS927B via a Honeywell RD666OD next to the boiler.
It all works well but the CMs unit has started to have problems with the display becoming unreadable. I understand that this is quite common. I also undersatnd that the CMS927B in no longer produced.
Could someone please suggest an alternative that has about the same level of features, preferably Honeywell, (simply because I have liked this one).
I do not need any IP/Bluetooth/Facebook type refinements. I'm old school and do not need to check my boiler pressure from outer space or anything like that.
Thanks fellas.
The nest is pretty good, because it learns how you want the heating and it knows the outside temp, so it can warm your house up a little earlier or later depending on the outside temp. I don't believe it has an interface to Facebook, but it does integrate to your phone, which makes programming it a lot easier than an old school digital calculator display.
Thanks for this ..... but
1. I wasn't literally serious about facebook ... if I'm honest I don't really know what facebook is ... and ...
2. The benefits you point out, "knowing outside temp", "learning how I use the heating" etc are exactly what I would like to avoid. I really don't get on with technology that wants to second guess me. I just want to be able to tell it .. simply ... what I want it to do and have it do that thing there.
I know I'm out of touch with reality and I'm okay with that ;)
Thanks all the same though.
