Hi so following an issue with the bottom of radiators being hot but about 90% of the rest of each radiator being cold, I checked the Honeywell valve V4043H1056. The actuator on the side was loose when the central heating is off, unlike another one that is present. I took the synchron motor out to have a look, when I turned the electric back on it was spinning constantly (don't know if this is normal). I then refitted and this time the actuator seemed to connect with the spring, I could feel the resistance. Trying to turn the central heating on again, this time there is nothing going to the radiators (whoops) - and now the actuator seems not to be connected to the spring again....any ideas please?
