Hook and Band hinges
15 Nov 2005
South
Cook Islands
I bought some H&Bs for a wooden garden gate. I did not realise that cranked ones would set the inside face of the gate flush with the posts, I bought straight ones, and I see that the inner face of the gate will end up 12mm or so beyond the posts.
Is there a way to do it more tidily?
Can the pin plates be sat on the side of the post, with the gate in the middle of the posts? The gateposts are about 200mm wide and 35mm thick because they are fixed to a wall.
There is no stop yet, I will fix it once the gate is hung.
JohnD, good evening.
A couple of thoughts?
1/. Would it be possible to fix the hook on to 200.mm "face" of the post, but I think that this would result in the gate needing to be reduced in width?? so the clearance and swing of the gate is not impeded.
2/. A possible second alternate? how about you have a look at cutting a couple of notches in the post? into which the hooks could be fitted? that should then align the gate edge with the post. A coat of preservative on the cut surfaces will protect the timber post to some degree, the cuts on the post could be part by a saw, but most by a seriously sharp chisel?
Ken.
