I have recently purchased a hot tub which is heated via the Electric. The result is 11.5 kw of Electricity used daily just for the Tub. I have decided this is too costly and have started searching for alternative heating.
I have been looking at a Bowman EC80 Heat Exchanger which connects to your Central Heating System.
Has anyone installed similar systems?
I have some queries on whether this can connect directly to my pressurised combi boiler as some of the examples show header tanks.
Also rather than heat the whole house would i be right in assuming i would fit a three way valve to divert the heated water through the heat exchanger for the pool feed , although by doing this i am unsure how the return would feed back to the boiler unless you would use two three way valves to create a seperate circuit in effect.
Thanks for any input.
