Hot Water, boiler overrun ..
27 Dec 2007
I recently changed the suite in my bathroom, but i have a situation where by when i turn the hot tap on everything is great but when i close the tap i can still hear the boiler burner going for 3 or 4 seconds once the tap is closed.
The boiler is a 'Main Medway'
is this normal? i dont seem to remeber if the boiler was overunning prior to changeing the bathroom suite and there are no other problems at all.
any advise would be appreciated
thanks
Graham
have you altered pipework and capped some point off leaving air in a length of pipework somewhere ( a dead leg) you will need to bleed this air off as it could be causing movement of water through the boiler for a couple of seconds keeping the burner on before it stabilises
As gushie says lok for dead legs.
But if there are none and it stays on any longer than this you will need to get someone out to strip water section out of heater and make sure they clean and grease the pin as this sticks and keeps gas on which can cause heater to blow the water pipes off joints causing a flood and also give someone a nasty burn
