Hope knowledgeable people can help on this one as they have in the past. Thanks to this list I've fixed at least 2 boilers.
Recently moved into a place with this oldie but goodie boiler which worked fine for HW and CH till a few days.
HW is still fine - coming on/off from the Honeywell control panel and is also controllable via the thermostat knob.
Boiler does not come on when CH is activated from controller. I hear a microswitch click from the controller but the boiler does nothing. I checked the overhead cold water tank that feeds the boiler - it was empty. Refilled it. Can see why water to it was turned off at the tap - the float operated valve does not close water off fully resulting in overflow onto balcony. I refilled the tank but still no go for CH. Note that one radiator still warms up when HW is on thanks, presumably, to the heat exchanger.
Given that this is not a fully sealed system I thought there may be some airlock preventing detection of adequate pressure. (There is no pressure gauge.) If that is a cause - I didn't see any instructions in the install/service manual. Also the diagnosis chart does not mention my scenario so can't do the dumb old follow-the-graph-to-the-cause approach.
Suggestions please? Much appreciated.
