Hot water filter? Pressure relief valve
4 Jan 2009
Herefordshire
%5BURL=http://smg.photobucket.com/user/AndyPK/media/8D0ACD2D-9E8A-4A73-89F8-1D591198BA88_zpsxekmimnd.jpg.html]
%5BURL=http://smg.photobucket.com/user/AndyPK/media/B154AC9F-6023-4664-99F5-E7AE75D314F8_zpstch4mz6f.jpg.html]
I have this system in my house.
I intend to change the stop cock because it doesn't work.
Out of interest could someone explain what the 2 items are and do please.
I ask for 2 or 3 reasons.
1. Previously when I have turned the water off at the mains to perform work on the hot water taps, the water is off and then suddenly there will be a significant amount of water comes out and makes a mess, and then stops. I assume that white cylinder is causing this ? Even if I replace that stop cock and use it, it will still have the same result. How do plumbers work round this?
2. I do get a drop of water out of the external pressure relief pipe. This can come from 2 sources. That bar thing out the back, and a pressure relief valve ontop of the cylinder. (I actually think it's coming out of the cylinder one)
3. At some point I will need to get a qualified (unvented) plumber to replace that thing with the limescale on. I have previously been told it's a filter? Seams to have too many pipes though? So that I can purchase one to have on hand, what am I looking for?
Send the pics to whoever is going to do job and they will keep you right. Needs someone with unvented hot water qualification
just done a bit of a search
So it's a pressure reducing valve and strainer.
With a cold water output to match the pressure of the hot (I guess this does the shower/bath)
Maybe a non return valve in their somewhere.
Then the expansion vessell for when the water heats up.
and expansion valve blow off.
Have to have a read.
