Currently having problems with my boiler where the hot water keeps cutting out after about 4 minutes. The boiler's an Avanta Plus 35c.
The radiators work fine and will happily come on and off but when using the hot water taps it's fine for a while then shuts down the boiler and registers an error E7. Manuals not much help as it seems to be geared to the radiator system checking water pressure/pump which I assume are OK pressure's around 1.5bar and the pump is probably working ok as the radiators are fine.
Any ideas of whats likely to have gone wrong ? Does the hot water have a separate temp cntrol that may be tripping/any liekly blockage causing it to shut off (water flows through fine even if it is cold though)
