i have a servis m3094 washing machine. when the cycle has finished the clothes are VERY hot. the machine is obviously rinsing with hot water before the final spin.
I read in the manual that the machine can be hot and cold fill or cold fill only. i assume cold fill only means it will heat the water for itself instead of using all the hot water from the storage tank. i tried simply turning off the hot valve and started the machine up to do a load but the machine didnt fill so i turned the hot valve back on to allow the machine to fill then i immediately came on here.
is there something i need to do in order to use the machine as cold fill ? (do i need to transfer the current hot hose to the cold valve?)
please help!
any advice greatly received.
please help!
